China Home Dehumidifier
astao266
New member
30LPer Day portable Air Dry Dehumidifier Mini Elders' room Dehumidifier
Features:
1.Automatic humidity control and defrosting,RH30-90% arbitrary adjustment.
2.Humidity, temperature dual display, can query dew point temperature.
3.1-24 hours regular shutdown setting,three minutes delay start, protect compressor, over and under voltage protection.
4.Fully plastic and rigid body, making the machine lighter weight and elegant appearance, never rust, high life dehumidifier fan motor, quiet, low noise.
5.Microcomputer automatic defrost, suitable for low temperature environment.6.Than mechanical automatic defrosting.
7.More reliable, more accurate.
Technical parameters:
ModelSD-301B
Product NameElders' room dehumidifier
Humidity Removal30L/D(30掳C,80%RH)
Rated Power Input630W
Power Source220V-50Hz
Current3.0A
Circulating Air680m3/h
Work Temperature5-38掳C
Applying Space30-50m2
Noise鈮?5dB(A)
Drainage ModeDrainage with tank or external hose
Net Weight31Kg
Dimension(mm)340*450*641
Our services:
A year warranty for the whole machine, not including the man-made damage or damaged by wrong operation or changing the inside constructure without our engineer's permission. During the warranty time, we would send the spare parts for repair but the spare parts that provided together with the bulk production can not be sent for free again.
FAQ:
1.Why do you choose our products?
Because our company has engaged in dehumidifier industry for 7 years and quality can be guaranteed.
2.Can we give you some discounts?
Yes, it will depend on the quantity you buy from us.
3.Do we have product warranty?
Yes, most of our products' warranty are at least 1 year.China Home Dehumidifier
website:http://www.dehumidifier-sd.com/dehumidifier/home-dehumidifier/
