Frontend Publishing Pro - WordPress Post Submission Plugin - Download Frontend Publishing Pro - WordPress Post Submission Plugin Nulled Free CodeCanyon 8517990
If you want to give your users the ability to create posts from the front-end area then Frontend Publishing Pro is the perfect solution for you. It works well with custom post types/taxonomies and comes with a simple drag and drop interface for easy form building. Thanks to the included shortcodes you can...
