Gravity Flow WordPress Plugin - Download Free Gravity Flow WordPress Plugin Nulled
Feedback & Review Loops
Modify forms before approval
Implement review loops allowing users to edit their values before re-submitting for approval. Use workflow conditional logic to branch the process or skip steps.
Rapid Implementation
Simple and easy to use
Configure as many Workflow Steps as you need. Drag and drop them into the right order, activate/deactivate them and add new ones as your process adapts. No programming...
