Rules of survival Rules of Survival – Explanation for all the weapon accessories
Rules of Survival rules the roost on Mobile with a huge number of players. However, because of the Battle Royale style with a large-scale gameplay system and a huge map, the game still makes many people feel vague about the aspects of gameplay. So, soon after the weapon tutorial, GameHub will continue to introduce the mechanism and effect of each accessory in the game.
Muzzle (Recoil Compensator)
Muzzle is divided into 3 categories for each Rifle, SMG (submachine gun) and SP (sniper rifles) with the same effect.
  • Silencer: Reduce the sound and the spread of the bullet.
  • Compensator: Reduce the vertical recoil and horizontal recoil. Reduce the spread of the bullet.
  • Flash Hider: Remove the flare and reduce the vertical recoil and horizontal recoil.
  • Choke: Shotgun can be equipped with Choke, which reduces the spread of the bullet and slightly increases the rate of fire.
Foregrip
Foregrip is equipped only for Rifle and SMG. There are only two types of Foregrip: Vertical Grip and Triangle Grip.
  • Triangle Grip: Slightly reduce the vertical recoil and horizontal recoil, as well as increase the open Scope speed.
  • Vertical Grip: Remarkably decrease the vertical recoil and horizontal recoil.
Scope
  • Regarding the Scope, there is probably no need to explain. Beside Holo and Red Dot in normal mode, some types of Scope such as 2X, 4X and 8X have already clearly stated their features at their name.
Mag
  • Mags are generally available for all types of guns and are divided into three categories: QD, EX and QD-EX. As the suggested name, QD allows you to increase reload speed, EX boosts the number of bullets per mag and QD-EX combines the strength of both.
Stock
Unlike Grip or Muzzle that has its constant effect through a wide range of weapons, Stock changes based on Rifle, Shotgun and Sniper.
  • M4 Stock: For M4A1 only. Significantly reduce the vertical recoil and horizontal recoil.
  • SG Bullet Loop: Significantly decrease reload time
  • SR Cheek Pad: Significantly reduce the vertical recoil and increase the reload speed.
GameHub will continue to publish the analysis and guidance of Rules of Survival for readers in the future.
Readers can also participate in discussions with Vietnamese gamers here:
