Elementor Shortcode Designer for Modern Events Calendar (MEC) - You can rearrange the widgets using Elementor to achieve the desired view and place it on a page
This addon allows you to create shortcodes with your desired layout. You can rearrange the widgets using Elementor to achieve the desired view and place it on a page. It is possible to control the number of events displayed or even turning on/off tiny little things like the map view at the top of the shortcode. It also includes both Simple and Modal display methods and a lot more.
Key Features
Exclusive...
