Elementor Single Builder for Modern Events Calendar (MEC)
NullMaster
NhatKyThuThuat.com
Elementor Single Builder for Modern Events Calendar (MEC) - Create a ready-made template for all your events with Elementor
screenshot_22-png.37197
With the help of this add-on, you will be able to create a ready-made template for all your events, add styles that you like to your single events, and change the layout in Elementor with a single drag and drop. Also, if there is a widget that you do not like, you can delete it and use other widgets in the single event of your website. You can use all the widgets of the single event separately and create any section that...
